Power Supply requirements
Solved by Thorium19,
I would suggest you have a look here, as it will give you the info you need. IF you intend to crossfire, then an 800W is the most you will need IMO, unless you really are going to be stressing it. http://linustechtips.com/main/topic/199255-how-many-watts-do-i-need-check-here/
power supply choice for your situation in my view would be the EVGA supernova 850G2, which is 80plus gold, and has the wattage you will need with room for Xfire, as well as being very good quality with good components inside.
