Hello forums,
I'm again in need of Python help.
This is what the question is asking us to do.
Given two words with the same number of letters in each, work out how many letters need to be changed to get from the first word to the second. A more complex version of edit distance is commonly used in spelling auto-correct algorithms on phones and word processors to find candidate corrections.
The two words should be read from the user with one word per line. For example:
Word 1: hello
Word 2: jelly
2
That's because h needs to be changed to j and o needs to be changed to y.
This is my coding at the moment:
word1 = input("Word 1:")
word2 = input("Word 2:")
word = 0
for word in range(word1,word2):
  print(word)
word == word + 1
Please help!
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/207377-python-help/
You will need to enumerate both words and iterate over the characters, comparing them to each other. So something like:
    changes = 0    for char in word1:        for char2 in word2:            if char != char2:                changes = changes + 1
Now this is a very naive implementation and does not take care of differences in length of the words etc. but this might get you somewhere...
Basically what you are looking for here is a Levenshtein distance algorithm, loads of resources about that on the wide web.
https://linustechtips.com/topic/207377-python-help/#findComment-2813795
Well, I'v got this, not sure what to do next. Any tips :)
word1 = input("Word 1: ")
word2 = input("Word 2: ")
changes = 0
for char in word1:
 for char2 in word2:
   if char != char2:
        changes == changes + 1
print(changes)
https://linustechtips.com/topic/207377-python-help/#findComment-2814025
This is what I've come up with:
#get inputword1 = raw_input("Enter the first word: ");word2 = raw_input("Enter the second word: ");#get length of wordslength1 = len(word1)length2 = len(word2)#print "Your first word is %s and it's %s chars long." % (word1, length1);#print "Your second word is %s and it's %s chars long." % (word2, length2);if length1 != length2:    print "Those two words aren't the same length!";else:    diff = 0    count = 0    for char in word1:        if char != word2[count]:            diff = diff + 1;            count = count + 1        else:            count = count + 1    if diff == 1:        print "There is %s difference between %s and %s." % (diff, word1, word2);    else:        print "There are %s differences between %s and %s." % (diff, word1, word2);
"Everybody wants a happy ending, right? But it doesn’t always roll that way." - TS
https://linustechtips.com/topic/207377-python-help/#findComment-2816145
