So my Borderlands 2 was running at a very low framerate on my 780ti so I checked and it was only at 60-65%. It is OC and have it set to prioritise temps and it isn't going above 75 degrees. Could my 4.4ghz 3570k be bottlenecking it? This is not occuring in any other game I have played.
Ninja Edit: Turns out PhysX was running off of my CPU..... yeah....
https://linustechtips.com/topic/206734-low-gpu-utilization-in-borderlands-2/
What's you CPU usage?
What do you consider low framerate? Works OK for me even with my vintage HD6950 (before I crossfired it even).
"Fighting for peace is like screwing for virginity"
- George Carlin (1937-2008)
Try setting the priority to high in task manager
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
CPU is at %100
Well there you go...
Owner of a top of the line 13" MacBook Pro with Retina Display (Dual Boot OS X El Capitan & Win 10):
Core i7-4558U @ 3.2GHz II Intel Iris @ 1200MHz II 1TB Apple/Samsung SSD II 16 GB RAM @ 1600MHz
CPU is at %100
Weird. My 3570k@4.2 get about 80FPS in heavy areas. Maybe you got something else eating CPU cycles? Could also be PhysX playing up. Maybe you should turn it to low if you got it on high.
