Hello,
I was wondering if it was possible to update the firmware on my SSD without having to re install windows and other programs.
I'm currently experiencing some random freeze ups and I thought it may have been the ssd.
I know that you need to create an iso image on a usb for it and boot in the usb, i just don't want to go through the hassle of installing everything again. is this possible or should i just not bother with it (does the firmware make much difference anyway).
Thanks for reading.
DB
https://linustechtips.com/topic/20627-firmware-question/
It usually is, but typically you'll want to make a backup as most manufacturers will not guarantee that it will work. There's always a chance it will cause problems. I think I did it on an old OCZ vertex drive without any problem though.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/20627-firmware-question/#findComment-248058
