Motherboard and cpu
Go to solution Solved by Pc elite,
I'd say a Asus Z97-A and a i5 4690K
If you've got enough money then maybe get a i7 4790k for the hyperthreading, that will help if you plan to do video editing; far from necessary though if you only plan to do a bit, you'd be better of saving the money in that case.
"Maybourne, you are an idiot every day of the week; why couldn't you have just taken one day off?!" —Samantha Carter
https://linustechtips.com/topic/206265-motherboard-and-cpu/#findComment-2799540
