What brands are available there?
I might be familiar with some of them...
https://linustechtips.com/topic/205693-best-bugdet-phones/#findComment-2791695
Moto E is good but lacks auto-focus camera and a front cam. Asphalt 8 won't run very smoothly on the Moto E. If that doesn't matter a lot then go for it. If you can extend your budget then get the Moto G for overall better android experience.
What is your budget?
https://linustechtips.com/topic/205693-best-bugdet-phones/#findComment-2791716
Minecraft: Pocket Edition is intolerable for me because Multiplayer is only possible through that overpriced shit known as Realms.
The Dude's PC Build<p>i5 4690k @ 3.5ghz w/ The Crappy Intel Stock Cooler | Asus Z97-K | 8GB Corsair Vengance LP DDR3 RAM @ 1600mhz |1TB Seagate Barracuda + 120GB Samsung Evo SSD | Gigabyte Windforce R9 290 4GB | 650 Watt CoolerMaster Gaming Series PSU | Bitfenix Shinobi Windowed | BenQ GL2460 | Corsair Vengeance K70 Cherry MX Brown | Razer Naga Hex Wraith Red gaming mouse | A £0.63 mouse pad from artcow.com
https://linustechtips.com/topic/205693-best-bugdet-phones/#findComment-2791797
8000 indian money or roughly 133 USD
i just need a phone i can use for a while
https://linustechtips.com/topic/205693-best-bugdet-phones/#findComment-2791917
if you are open to other OS, Lumia 525 or 630 would be my recommendation. Got any Oppo phone in India? i went to have a look at them today and surprisingly even the low end Oppo Joy operates quite smooth and fluid. And it is only like $110 here.
https://linustechtips.com/topic/205693-best-bugdet-phones/#findComment-2791962
i really need android
https://linustechtips.com/topic/205693-best-bugdet-phones/#findComment-2791983
here is a link to amazon india and flipcart india
amazon: http://www.amazon.in
flipcart: http://www.flipkart.com/motorola/motoe
these are the online shops in india.
Browsed through the amazon site...
LG L60 (August 2013 release) or Huwawei Ascend Y600 (surprisingly smooth when I tried one in-store, not too impressive though)...
The Karbonn ones seem familiar but I haven't tried any of their units...
https://linustechtips.com/topic/205693-best-bugdet-phones/#findComment-2792073
define not too impressive though
https://linustechtips.com/topic/205693-best-bugdet-phones/#findComment-2792133
you can multi if the devices are on the same wifi source if you want i can make a video on it
Plox
https://linustechtips.com/topic/205693-best-bugdet-phones/#findComment-2792177
It's not flagship level, but it's better than most of the 100USD crap that is sold in my country...
If there's an Alcatel in your choices, do not buy it... My mother uses an Alcatel OneTouch Idol (?) and it heats up pretty quickly... Battery life is crappy, and it's slightly sluggish...
The L60 has a decent SoC... Again, it's not flagship level, but it should run most of what you're planning to do with it at an acceptable performance level...
The Huawei one is a step below the L60, but they're pretty much on the same level...
I'd suggest Gionee if I've tried them already... Too bad the local shops won't bring out live samples...
https://linustechtips.com/topic/205693-best-bugdet-phones/#findComment-2792187
Plox?????? WAT
Plox is a rather sophisticated way of saying "Please".
https://linustechtips.com/topic/205693-best-bugdet-phones/#findComment-2792221
do they have longer battery life than the moto e
https://linustechtips.com/topic/205693-best-bugdet-phones/#findComment-2792228
For the LG, I think it can last 2-3 days with light usage... (estimate based on experience with an L3 E400R which can last up to 4 days on a single charge)
For the Huawei, somewhere around 2 days...
I'm not sure how it would compare to the moto E since I haven't seen one here...
https://linustechtips.com/topic/205693-best-bugdet-phones/#findComment-2792251
