Hello all!
So i have noticed recently that my microphone level in the windows recording devices has kept resetting itself every time i restart my PC.
I would have it set to 20 and then when i restart it is at 100.
It's really annoying having to adjust it every time i logon.
This is the setting below
http://prntscr.com/4ha4x7
I'm using Windows 7 64 bit.
If you need any other info i will provide it  :lol:
https://linustechtips.com/topic/205660-microphone-level-reset/
Does your clock change?The time,after a restart or any other setting at all
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/205660-microphone-level-reset/#findComment-2791514
Nope. Clock stays the same as well as the date
I don't know is strange from all the settings that a computer have only that one changes
https://linustechtips.com/topic/205660-microphone-level-reset/#findComment-2791595
I have noticed that this only happens when i launch games such as Counter Strike GO. I will change the volume to 20 and when i launch the game it slides itself back up to 100.
Main: i7 2600 | ASUS P8Z68-V | 2x4GB Vengeance 1600 | GTX 580 | WD Blue 1TB | Antec TP-650C | NH U12S | W7 x64
Backup: X6 1090T | MSI K9A2 Platinum | 4x2GB XMS2 800 | GTX 550Ti | WD Blue 1TB |  Antec VP-450 | CM TX3 | W7 x64
https://linustechtips.com/topic/205660-microphone-level-reset/#findComment-2809204
