not to sure if it is the mother board or not but at least 2 times a night I get a pop up that says "you just unplugged a device from the audio jack" then right a way there is a pop up that  says i plugged it back in.
the sound does not cut out when this happens. my computer is only 3 weeks old and this problem just started happening.
I use a razer kraken headset plugged in to the back I/O GREEN and PINK.
my motherboard is ASUS Z97-A
my friend said I should reinstall my realtek drivers but I haven't done that yet since I have been using the drivers fine for 2 weeks without any problems.
https://linustechtips.com/topic/205135-motherboard-problem/
