I was wondering if anyone can help me with a few things for school.
Some things possibly don't make sense, I used google translate for certain words.
1. Calculate the power(/output) of a machine which gets 15.000 kilo (=33069.3393 pounds) coal out of a mine which is 150 meters deep.
I'm pretty sure you'll have to use gravity or acceleration due to gravity here which is 9.81meter/second² (m/s²)
2. A block of steel (bulk density of steel = 7800kg/m3) with a volume of 80 centimeters(cm3) gets immersed in petroleum (bulk density of petroleum = 800kg/m3)
A) How large is the weight of the block of steel
B ) How large is apparent weight of this immersed steel?
C) How big is the upward force/uplift that the block of steel encounters from the petroleum?
https://linustechtips.com/topic/205113-school-help-physics/
-snip-
I'm just going to give some notes:
Power = Force * Distance / Time : It's the rate of doing work, where work is force x distance.
So 1 really confuses me since a "time" isn't given, so I assume it's really asking for work. Which means you have to use gravity * weight to get the required force to move the coal out of the mine, then multiply that by the distance (150m).
2a is just the bulk density multiplied by the volume considering decimal places (boldened because this is where I make errors 90% of the time).
2b is confusing since the total volume of the block of steel + the petroleum isn't given (or the volume of the petroleum itself), unless immersed doesn't mean what I think it means. It didn't mean what I thought it meant. See this post.
2c isn't something I can help on since I don't know anything about buoyancy in a "liquid" (quotes because petroleum is usually a viscous liquid AFAIK).
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/205113-school-help-physics/#findComment-2784488
W=m*g*h should help you out with the first one if I'm not mistaken.
It is said, that civilised man seeks out good and intelligent company, so that through learned discourse he may rise above the savage and closer to God. Personally, however, I like to start the day with a total dickhead to remind me I'm best!
https://linustechtips.com/topic/205113-school-help-physics/#findComment-2784500
So 1 really confuses me since a "time" isn't given, meaning I assume it's really asking for work, in which you have to use gravity * weight to get the required force to move the coal out of the mine, then multiply that by the distance (150m).
Yeah I had the second part for 50%. I calculated the Force (F) by using this formula: F=m*g Or in words Force equals mass times gravity acceleration.
https://linustechtips.com/topic/205113-school-help-physics/#findComment-2784506
Yeap I got that now :P Thanks anyways
Also, for your second question, part c. You might want to look/think about the "Law of Archimedes in liquids" ;)
https://linustechtips.com/topic/205113-school-help-physics/#findComment-2784522
Yeah I thought about that, but I don't know those formulas
F=density*g*V
Density of the liquid of course.
https://linustechtips.com/topic/205113-school-help-physics/#findComment-2784537
Yo, from the wiki (to see the 2nd & 3rd formulas better, don't be using Night Theme on LTT):
apparent immersed weight = weight of object - weight of displaced fluid
F=density*g*V
I assume V = Vsteel block? Does it matter that we don't know how much petroleum there is? I can't imagine it would.
https://linustechtips.com/topic/205113-school-help-physics/#findComment-2784552
As stated before, #1 is weird as there is a unit mismatch.
2a. mass = density * volume
2b. Not sure what its is asking here.
2c. You are looking for the buoyancy force. Fb = density of fluid * gravity * volume of solid. (although it should be noted that the steel is just going to sink to the bottom like a piece of...well steel...until it hits the bottom of whatever container its sitting in or the density of the fluid increased to the point where it equals gravity, wherein it would begin to float at that level.
https://linustechtips.com/topic/205113-school-help-physics/#findComment-2784561
It's basically asking how much the object effectively weighs after considering the force of buoyancy pushing up on the steel block. That's what apparent immersed weight is. The weight of an object in a liquid after considering the force of buoyancy, since the weight is apparently less than it is (due to buoyancy fighting gravity) while the object isn't in a liquid.
From Google:
Archimedes principle says that when an object is immersed in a liquid the apparent loss of weight of an object is equal to the upthrust and this is also equal to the weight of the liquid displaced.
https://linustechtips.com/topic/205113-school-help-physics/#findComment-2784579
F (N) = m (kg) a (m/s^2)
F = 15,000 * 9.81
   = 147,150 N
W (J) = F (N) s (m)   where s is the displacement parallel to the force vector
W = 147,150 * 150
    = 22,072,500 J = 22,072.5 kJ
This is the WORK done by the machine. it's not it's POWER OUTPUT. To determine it's POWER OUTPUT, you are missing data. you'll need how much time it take for the machine to lift the mass. That is because :
P (W) = W (J) / t (s)
https://linustechtips.com/topic/205113-school-help-physics/#findComment-2784590
F = 15,000 * 9.81
   = 147,150 N
W = 147,150 * 150
I meant work in that case, since I have to get a outcome with wattage
https://linustechtips.com/topic/205113-school-help-physics/#findComment-2784595
From Google:
Ahhh that thing...I remember having to derive that bloody formula in my fluid dynamics midterm because I forgot it. Funny thing was that my answer was more accurate than everyone elses because the accepted version makes certain estimates that I didn't...I was like 0.01% more correct YAY!
https://linustechtips.com/topic/205113-school-help-physics/#findComment-2784600
rho (kg/m^3)  =  M (kg) / V (m^3)
Hence :
M (kg) = rho (kg/m^3) * V (m^3)
           = 7,800 * 0.00008
           = 0.624 kg
https://linustechtips.com/topic/205113-school-help-physics/#findComment-2784606
Hence :
           = 7,800 * 0.00008
           = 0.624 kg
Shouldn't that be like 6240 kg? Since it has a large volume. 0.624 seems a bit light
I've done this: m = 7800kg/m^3 * 0.8m^3 = 6240 Kg
https://linustechtips.com/topic/205113-school-help-physics/#findComment-2784630
Mass (kg)
Weight (N)
Apparent weight : weight of object minus weight of displaced volume of surroundings
Weight_steel (N) = rho_steel (kg/m^3) * V_steel (m^3) * a_earth (m/s^2)
                           = 7,800 * 0.00008 * 9.81
                           = 6.12144 N
Weight_displaced_petroleum (N) = rho_petroleum (kg/m^3) * V_steel (m^3) * a_earth (m/s^2)
                                                    = 800 * 0.00008 * 9.81
                                                     = 0.62784 N
Apparent weight (N) = weight_steel (N) - weight_petroleum (N)
                                = 6.12144 - 0.62784
                                 = 5.4936 N
https://linustechtips.com/topic/205113-school-help-physics/#findComment-2784664
