so i have my 7970 and R9 280x i was wondering would i get a higher core clock if i enabled (force constant voltage)
IF you are OCing then it could possibly help,when I was ocing my 760 I noticed that having a constant voltage helped squeeze the last few Mhz outta the card.
https://linustechtips.com/topic/204695-overclocking-help/#findComment-2780358
