Recently I bought a modmic 4.0 to replace my zalman clip on mic and while the audio quality has increased the static is still just as bad. Initially I thought it was an issue with the microphone but after removing all possible sources of noise in my room it didn't help, so i thought it might be the driver so i re installed it, no such luck. My question is do i need to buy a sound card (I'm using on board atm) to get rid of this static? Is the onboard soundcard the cause of the static?
CPU: i7-3770k  Motherboard: MSI Z77A-GD65 RAM: Kingston HyperX 8GB COOLER: Noctua NH-U12S GPU: Gainward GTX570 STORAGE: 128GB OCZ Vertex 4 + Seagate Barracuda 2TB PSU: Silverstone Strider Plus 850W Case: Corsair 650D MONITOR: Asus PB278Q + BenQ G2420HD KEYBOARD: Ducky DK9008 Shine MOUSE: Steelseries Sensei SOUND: Beyerdynamic DT880 + Audioengine D1 OS: Windows 7
https://linustechtips.com/topic/204472-microphone-static-issue/
0 views? Is this bugged?
https://linustechtips.com/topic/204472-microphone-static-issue/#findComment-2776517
Guess that it then, thanks.
https://linustechtips.com/topic/204472-microphone-static-issue/#findComment-2776624
