graphical problem, caused by 2 different GPUs?
hi, so i have a PC on am3+ so no iGP, which had an HD 6850
and i was going to use this PC only for it's CPU so i removed fans from the AC accelero S1 on the 6850
but after some time i tryed playing a game a little on this PC, it went fine
but the next day i had a black screen, and then 6850 was not hot at all at this moment because of some houres at idle
the only thing i was able to see was using team viewer on this PC and sending a ctrl+alt+del
and when i move the cursor i get this
so i thought the 6850 had overheated, but wouldn't the problem should have appeared during gaming, or not at all because after a certain temperature the PC shut down?
i replaced the 6850 by an old GT220 i had lying around, wasn't sure if it still worked
the PC booted but still same exact problem, always black screen, only that via teamviewer (doesn't appear on the screen, i get a "no cable connected" message on any screens)
so, is it a problem from both GPUs so i need to get another one, or a motherboard problem maybe? (the PCIE plug could have been damaged since the 6850 heatsink was pretty heavy and the GT220 is low profile without bracket for full profile)
or something else?
https://linustechtips.com/topic/204311-graphical-problem-caused-by-2-different-gpus/
so, is it a problem from both GPu so i need to get another one, or a motherboard problem maybe? (the PCIE plug could have been damaged since the 6850 heatsink was pretty heavy and the GT220 is low profile without bracket for full profile)
or something else?
Are you able to reinstall Windows mate?
If you're switching GPUs willy-nilly you're probably gonna have some fucked drivers.
sound more like a mobo issue than a GPU issue to me
you got another PC to test the GPUs?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
nope, only have this one as desktop PC
do you think trying another PCIE plug could help or is it another kind of mobo problem?
if you mobo has another PCI-E slot for graphics
try that and boot to BIOS and Windows
still the same with GT220 on 2nd PCIE
looks like mobo issues already
of what kind?
because the fan of the GT220 is powered by the mobo at least so it know it have it there
internal problems
the lanes to the slots are not working properly
You probably messed a few lines from the increased power draw that gaming generates
CPU: i7 4770k@4.3Ghz GPU: GTX 780ti Motherboard: ROG maximus vi formula PSU: Evga supernova 1000w Platinum
Case: NZXT Switch 810 Memory: g.skill ripjaws X Cooler: Corsair h100i(getting custom loop when i get money next) Storage: Samsung 840 evo 250gb Keyboard: Corsair K95 Mouse: SteelSeries Rival
