CPU: FX-8530
Cooler: Thermalright HR-02
GPU: ASUS R9 280X-DC2T-3GD5
RAM: 8GB 2400Mhz Corsair Vengeance Pro
MoBo: ASUS M5A97
PSU: Corsair CS650M
Storage: Samsung 840 EVO Basic 120 GB/ WD Green 2TB
Case: Corsair Carbide 500R
My Budget is about 1000 euro.
Any tips or improvements?
https://linustechtips.com/topic/203986-first-build/
If I were you I would get 1600MHz ram, and replace the FX-8530 with a i5 4690K (or 4690 if you don't want to overclock), and a Z97 Mobo (Or H97 if you don't want to overclock)
https://linustechtips.com/topic/203986-first-build/#findComment-2769833
The price difference between 1600 and 2400MHz is literally 6 euro, so That differance is easily affordable, while switching to a 4690K  will cost me about 50 euro extra, which I can't afford
https://linustechtips.com/topic/203986-first-build/#findComment-2769878
Hmm, alright.
What exactly will you be using this build for?
https://linustechtips.com/topic/203986-first-build/#findComment-2770043
Gaming
That build you have will work fine for gaming.
https://linustechtips.com/topic/203986-first-build/#findComment-2770748
