Guys when i put the charger in the phone when its on its Not charging.i need to shut down the phone then i put the charger its opens automatically(like all apple phones) and then i close it again..with chargerin phone..tge only way it is charging
if you know a solution please tell
https://linustechtips.com/topic/203251-iphone-4s-battery-issue/
aaaaaaah i think its best if you contact apple about this
if you have warranty and all that is
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/203251-iphone-4s-battery-issue/#findComment-2758889
It could be the battery itself, a replacement is pretty cheap:
https://www.ifixit.com/Guide/iPhone+4S+Battery+Replacement/7111
http://www.macfixit.com.au/apple-iphone-4s-replacement-battery-with-tools.html
Alternatively it could be a problem with the charging coil or the software that controls how the phone charges. In that case the problem may not be rectifiable.
https://linustechtips.com/topic/203251-iphone-4s-battery-issue/#findComment-2758937
