Hey guys,
so I've trying to troubleshoot this myself for the past month with no success.
I ve been getting this irql_not_less_or_equal erorr, which i belive to be a driver error but after I did a clean install of windows and got the drivers from the asus website and it still happens and only stops after I remove 2 sticks of ram (which I just recently purchased a new set ).
my systems specs are
Intel 3930k
Asus Rampage Extreme IV
G.Skill 16GB Trident X @2400mhz
HD6970 CF
Corsair tx850w
Windows 7 Ultimate 64-Bit
https://linustechtips.com/topic/203213-bsod-irql_not_less_or_equal/
 I got the same error error yesterday with a single stick :(
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
memtest then
Also what's your voltage on CPU?
stock, because I'm keeping my cpu @stock
COOLING:
Force them to boot at 1333 MHz with this latencies
CL 9
RCD 9
RP 9
RAS 24
Command rate 2N
(9-9-9-24 2N)
And tell us
PS: use quote function...
so its been running at that for 5 mins now no error, ill try some games and stuff and see if it happens again. Sorry still getting used to using forums. (yes i have been living under a rock, on mars, with my finger in my ears)
