Microsoft XNA Framework 4.0 Installing problem
Hey,
Im having trouble installing Microsoft XNA Framework Redistributable 4.0.
It's needed to play Speed Runners, in steam everytime I try to open the game it says:
"Performing first time setup...
Installing msiexec (step 1 of 1)"
In steam it appears that i am in game but im not. After a few seconds im no longer in game and the process is closed.
The solution presented to me by the game developers was to install the program manualy. I tried and when Im in the middle of the installing Microsoft XNA Framework Redistributable 4.0 it says "Key not valid for use in specified state."
This guys have the exact same problem as I do.
I've been searching for some time and I cant find a fix. If anyone knows how to fix this I would appreciate some help.
Are you saying you're having trouble installing the bundled version of XNA Framework? Because you should probably just download it from microsoft directly. After that just install the game, and avoid installing anything bundled along the lines of DirectX/XNA etc.
http://www.microsoft.com/en-us/download/details.aspx?id=20914
I downloaded from microsoft directly and tried to install it and that's when the error ocurred "Key not valid for use in specified state."
  • 2 weeks later...
