Hey Guys hopefully someone will be able to help me quickly on this one,
My iPad won't connect properly to my build PC. No matter if I plug it in to a 3.0 port or a 2.0 one, It dosn't help.
On the iPad's side-
When I plug the iPad, it says "Trust this computer?" and the box will minimize and maximize repetitively. As well as the battery icon will repetitively go from "Not Charging [==]" to "49% [==]" to charging very quickly.
On the PC's side-
You can look at the attached images.
post-59840-0-35720700-1408835759_thumb.j
https://linustechtips.com/topic/202916-mtp-usb-device-not-working/
  • 3 weeks later...
That sounds like it's having trouble maintaining a physical connection. Have you tried using a different cable? Also, if that doesn't make a difference, what happens if you connect it via a USB hub?
Have you tried using a different cable?" Yes I have tried using a different cable but no luck.  "Also, if that doesn't make a difference, what happens if you connect it via a USB hub?"  I don't know if you phrased that correctly? But you've lost me on that one... I have tried other ports such as 2.0 / 3.0 on the back / front of my PC but still no luck...
1HyperCube1
My iPad Air does that too, but only on Windows PCs. Stupid Apple crap, I should have gotten a Android Tablet.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
Apple, one bite's already been taken out of mine... :(
the bitten Apple best resembles my feeling about the ipad. The build quality is super, but after using for half a year the software is really annoying me. Random crashes and youtube lags just on the ipad.
