Heres my build so far  http://pcpartpicker.com/p/nMBdGX    I would just like to make sure that everything is compatible. Will the noctua fit in my case and clear the ram, or should I get low profile ram? I mostly play open world rpgs, mmos, and dota 2 so im not sure which monitor to get. Do i need low input lag and response times for dota 2? My friend recommended this monitor to me http://www.amazon.com/EIZO-FS2333-BK-23-Inch-Screen-Monitor/dp/B00ASHTZYM/ref=sr_1_1?ie=UTF8&qid=1408668744&sr=8-1&keywords=eizo+foris+fs2333   but its only 1080p and 60hz , so it seems kinda expensive. Would I be better off going with a 120hz monitor or a 60hz 1440p monitor?
https://linustechtips.com/topic/201757-first-gaming-computer-build-help/
Use my build list :). I'm building it soon and yours look pretty similar. You can add the case fans if you want.
Thanks to the community for making this list for me <3
CPU Cooler: Noctua NH-U14S 55.0 CFM CPU Cooler  ($69.98 @ OutletPC)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard  ($139.99 @ Amazon)
Storage: Crucial MX100 128GB 2.5" Solid State Drive  ($73.99 @ SuperBiiz)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card  ($379.99 @ Newegg)
Case: Corsair Air 540 ATX Mid Tower Case  ($119.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.98 @ OutletPC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($84.99 @ NCIX US)
Total: $1302.53
Generated by PCPartPicker 2014-08-21 21:04 EDT-0400
Good build so far, though I'd throw in a H100i instead if you are paying that much for a cooler.
Drop the extra Noctua fans and put the money into an ssd.
The Corsair Vengeance Pro memory modules will not fit under the fan of the NH-D15. There are a number of options. I would suggest getting the NH-U12S which should not have memory clearance issues. Or you could go with Corsair Vengeance LP or G.Skill Ares memory.
