I'm running VirtualBox and the mouse while running an OS is unbearably slow and laggy. Everything else is running perfectly smooth but the mouse makes everything terrible. How do I fix this?
CPU: AMD FX 8320e | Mobo: Gigabyte GA‑78LMT‑USB3 | Cooler: Cooler Master Hyper n520 | RAM: 8Gb @ 1333MHz
GPU: Gigabyte GTX 1060 mITX | PSU: Antec HCG 520w | Storage: Sandisk 120GB - WD Red 1TB | Case: Modded IBM A50 sleeper
All displayed on an AOC I2421VWH
https://linustechtips.com/topic/201729-virtualbox-mouse-help/
What is the Guest machine?
The OS? It's running Ubuntu from a flash drive and Tiny Core Linux
https://linustechtips.com/topic/201729-virtualbox-mouse-help/#findComment-2735600
have you installed VirtualBox guest additions???
Whenever I try, It the os either comes back with an error or crashes.
https://linustechtips.com/topic/201729-virtualbox-mouse-help/#findComment-2735660
Is that Guest OS or Host OS?
The guest OS crashes, the program and host OS stays fine
https://linustechtips.com/topic/201729-virtualbox-mouse-help/#findComment-2735682
That's odd. It finally accepted the iso for the additions.
https://linustechtips.com/topic/201729-virtualbox-mouse-help/#findComment-2735694
https://forums.virtualbox.org/viewtopic.php?f=6&t=27089
I shall divert you to this forum as it will probably explain it better than me :)
Or this : http://askubuntu.com/questions/321589/unable-to-mount-the-cd-dvd-image-on-the-machine-sandbox
Computer Programming Nerd Guy + Computer Support @ Red Tree IT
https://linustechtips.com/topic/201729-virtualbox-mouse-help/#findComment-2735735
