Hello.
Can you give me a secure Power Supply for This config:
G.Skill DDR3 8GB
Western Digital 1TB WD10EZRX Blue Sata 3
CoolerMaster N400 black
MSI 4GB R9 290 Gaming
Msi Z97 Gaming 5
Intel Core i5-4690K
What is your budget and are you buying it from here: http://moddingworld.pt/
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/201598-secure-power-supply/#findComment-2761560
550W will do fine.
Assuming you are buying from moddingworld, the EVGA G2 750W is 119.26, the Seasonic G 550W is 103.68, the Superflower Golden Green 550W is 80.44, the Corsair RM550 is 103.26, the Antec HCG-520 is 72.71 and Truepower 550C is 92.69, and EVGA 600B is 67.48.
So, it depends on your budget.
https://linustechtips.com/topic/201598-secure-power-supply/#findComment-2762382
