Was wondering what other people's experiences are with OC'ing Phenom II's - and thoughts on my temps?
AMD Phenom II 965 C3
Idle - 29c
Gaming - ~49c
Prime95 - 55c
FSB: 200
Multiplier: x19
CPU-NB: 2600mhz
Voltages-
Vcore: 1.475v
CPU-NB: 1.3v
Ram-
9-9-9-24-1T @1.65v
If i lower the CPU-NB to 2400mhz, i can lower the voltage to 1.22v, and bring the max temps in Prime95 down to 52c, but from what i've read OC'ing the CPU-NB helps a lot with these old AMD chips. Also, i have Cool N' Quiet & C1E enabled with this OC, and it's stable.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/200914-thoughts-on-phenom-ii-temps/
Most C3s can do 4Ghz, try feeding it a bit more voltage you have 10c of headroom.
My mobo doesn't allow me to change the LLC, which means i need more volts to get stable. For 3.9GHz, i need 1.49v and hit ~57c. For 4GHz, i need 1.52v, and hit around ~65c. This is with the CPU-NB OC'd to 2600mhz.
I have my rig on for practically 24/7, so i'd rather keep it under the ~62c AMD recommends.
Have you updated the BIOS? Or is it a old rev of the board that didn't have LCC?
BIOS is up to date, and there is no LLC option there.
Running V20.3, latest one from MSI's product page for my board.
2JGC52y.jpg?1
That's a bummer :(
That's a bummer :(
Think i'll grab an FX-8350 for christmas.
Or an 8320 ;)
or take it as a sign and move to the dark side
Or an 8320 ;)
AMD is the darkside, since they always end up losing in the long run. :(
guess there's no reason to invest more into their platform then :)
I had a 955 @ 4Ghz@1.486v 2600NB @ 1.26v and it routinely ran ~65c at small FFT load so long as its stable don't worrie about the temps you don't need to be worried about hurting something until 80c It will get unstable and crash long before it gets that hot tho
Been dicking about with voltages again. Passed an hour of Prime95, currently been playing SWTOR for ~3 hours without a hitch, seems stable.
1.5v vcore @4GHz
1.32v cpu-nb @2600mhz
Idles ~30c
Gaming ~50c (hovers around 47c, but peaks 50c at times)
Prime95 ~57c (with cpu fan @80%, run with a custom fan profile so i idle with 20% fan speed, goes up to ~42% when gaming)
Wish i could alter the LLC, this board has some fucking stupid vdroop.
