So my iPod has very little space left. I wanted to add more music and I had to delete some other music in order to make room. Even though there should of been room, when I tried to sync it, it gave me an error that it couldn't sync (song names) because there was not enough room. So I deleted more songs and then all of a sudden when I synced it again, I had more than enough room. I thought ok...So I then tried adding more. I added one song and told it to sync and instead it showed it was copying 13 others including the one I added. I added 1 other and it again was trying to copy 23 others. Every time (3 times), I tried to add 1 song and it synced it, I had even more space left on my iPod....What???? I don't get it. I closed iTunes and re-opened it. Now it showed my iPod was over capacity by 2.16gb. But then after a few seconds that went away. It happens whenever I start up iTunes. To add to the confusion, my iPod shows it has 25.1gb of music used. I only sync to iTunes. However my iTunes music folder has used 23.7gb. What's up?
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/200595-itunes-problem/
Restore your iPod.
Also, i guess it's an iPod Classic, which year ? these symptoms could mean a defective hard drive
It's an iPod Touch, 5th gen 32gb
https://linustechtips.com/topic/200595-itunes-problem/#findComment-2719333
That removes the hard drive failure, restore it then resync everything, also update iTunes if not already
I did and it's still messed up. My iPod says there is 2gb free. Same as iTunes. Everything is synced. If I add 1 song that is 140mb, iTunes will say over capacity by 48mb.
https://linustechtips.com/topic/200595-itunes-problem/#findComment-2719841
