Ok so ever since I've had my new computer and here are the specs
https://uk.pcpartpicker.com/user/Matthew12106/saved/4XFbt6
I have had this noise issue. From the moment I turn on the case it is just too dam loud. Now I've ignored it for quite some time but not that I'm using my computer more often I want to do something about it. So I'm pretty sure I already know why but still I'll ask. Now I have a zalman z11 plus case. The most regretted component of the entire computer. This is quite the budget case... Anyway so here is an internal look at the fan config
You can't actually see it in these pictures but there are 2x exhaust fans, one in each side panel as part of Zalman's unique HDD cooling solution demonstrated in the following picture.
So altogether there is a total of 5 fans installed on this case. Now as I said this is quite a budget case and for some reason 3 of those fans use a molex connection meaning they run at full rpm. Now those two side case fans are 80mm and everyone knows the smaller than fan when you run it at full rpm it's gonna make allot of noise. My question is are those two fans actually necessary. It's part of their unique HDD cooling solution but all I have in there is a segate barracuda 1tb (I also have an 840 evo but that is mounted behind the motherboard so I doubt those two fans are going to be effecting it at all). Anyway so as I said I only have one HDD in there there for there probably isn't allot of heat being given off. I have a feeling that unplugging 2x full rpm 80mm fans would make the system allot quieter. Now I really want my HDD to have a long life and It should because it does have basically front row seats to my 140mm intake so It shouldn't be getting to hot now should it. To sum up should I unplug them. If I do I obviously will be doing some testing with it's temps using openhardware as I'm typing this it says that it's at 25C which seems reasonable.
My Gaming Setup: CPU: AMD FX-8350  |  CoolingCooler Master Hyper 212 Evo   Motherboard: Asus M5A97 EVO R2.0   Ram: Corsair 16gb 1600mhz lp (2x8)   GPU: Msi Gtx 970 |  StorageSeagate Barracuda 1tb & Samsung 840 Evo 120gb   PSU: XFX 550w Core Edition   Case: Corsair 760t   OS: Windows 7 Professional 64 bit
Peripherals: Keyboard: Corsair K70 Cherry Mx Brown   Mouse: Corsair M65 Black   Speakers: Microlab FC20 40w 2.1   Monitor: LG 29UM65 29" 2560x1080 IPS 5ms Ultra Wide
https://linustechtips.com/topic/200366-case-noise-problem/
Do it and keep an eye on the temps.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/200366-case-noise-problem/#findComment-2716034
a
https://linustechtips.com/topic/200366-case-noise-problem/#findComment-2716090
Did a run of vallye so my gpu could start spitting some hit air into the case.... the temp of the hdd rose I think my one degree (With the fans installed)
https://linustechtips.com/topic/200366-case-noise-problem/#findComment-2716094
What temps is okay for the hdd because I'm not going to be doing the testing now
https://linustechtips.com/topic/200366-case-noise-problem/#findComment-2716101
According to segates website the operating temp is 60C.... Seems like I have allot of headroom
http://www.seagate.com/as/en/internal-hard-drives/desktop-hard-drives/desktop-hdd/?sku=ST1000DM003#specs
https://linustechtips.com/topic/200366-case-noise-problem/#findComment-2716116
That's probably the max operating temp. I would try to keep it in the 40s, maybe the lower 50s.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/200366-case-noise-problem/#findComment-2716141
Ik I'm just saying that It seems like I have some headroom
https://linustechtips.com/topic/200366-case-noise-problem/#findComment-2716169
OK took out the two fans and after a run of valley the temps were 1C lower O.o
https://linustechtips.com/topic/200366-case-noise-problem/#findComment-2716298
That's possible. They could have been causing some turbulence in the front, basically screwing the airflow.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/200366-case-noise-problem/#findComment-2716317
