So I have a slight problem with GPU cooling in my Bitfenix Prodigy case. I have the blue one, which comes with a windowed side panel. This is great for water cooled GPU's as you can see the beautiful water block, but for an air cooled card like mine (XFX Radeon HD 7950 with the DD dual fan internal exhaust cooler) it basically suffocates it to the point that it runs at 100c under normal gaming load. As you can imagine, it is extremely loud, and also bad for the graphics card. I have a water cooling loop, but it uses a 5.25" bay pump/res combo unit. There is nowhere to put it in this case. And I currently do not have the money to afford a new pump, resovoir, as well as a GPU block. Does anybody know if there is such a thing as a non windowed blue side panel for this case? If so, where are they sold? Cheers  :P
P.S. One solution I though of was doing one of those mods where you use an AIO liquid cooler on the GPU. Does anybody know of a kit that would work with the 7950? Thanks.
https://linustechtips.com/topic/200348-gpu-cooling-problem-in-bitfenix-prodigy/
