Im going to using a GTX 780 (Even though there great without oc)
But i saw a guide oc it but they didnt exactly fiddle with the voltage.
If i were up the voltage, is it by increments and how do you know how much voltage your feeding it is safe?
Sorry im a noob :P
You can crank it up all the way on stock bios if the heat doesn't get you.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
Well i was thinking of boosting the base and memory clock. Of course with proper Cooling
OK? I'm a little confused as to what you're asking then.
I thought you were asking about voltages and if they could damage your card.
As @Jodomcfrodo said, you can crank the stock voltage all the way up with the stock bios.
woah, wasn't I just playing BF4 with you?
Lol, you're right! Your name just sunk in, haha.
I thought you would have like 60 posts or something, not 3700 when we were playing. Didn't know you were active on the forum.
Okay lets just say, If i were to have modified things other than voltage but the temperatures are still under control. Is it safe to add extra volts to the GPU?
Most modern Nvidia GPU's will only allow a maximum of 1.212v, it's hardly an increase so just go ahead and turn it to that.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
If overclocked, is it safe to add voltage? Yes, it is very safe and also used to make overclocks more stable.
The more volts the more heat generation correct?
(sorry just want to be very sure before i even decided on doing it)
Yep, I'm pretty active on here during my off time.
Correct
