GTX 780 Power
Go to solution Solved by Aniallation,
CPU: AMP FX4100 Quad Core CPU
Motherboard: MSI 760GM-P34FX
Welcome to Linus Tech Tips! Your CPU will be bottlenecking your GPU. Best choice is to upgrade your CPU. The maximum your motherboard can do is an FX-6300. That woulld be an improvement but it's recommended you upgrade both motherboard and CPU to get the most out of the 780.
Hello everyone I just reccently upgraded my GPU to a EVGA GTX 780 and I want to play battlefield4 but I dont know if it can handle it at high settings. If anyone could help out and tell me how it preforms that would be awesome.
My Specs:
Ram: 8GB of GDDR3 RAM
If you need any other specs I'll be happy to provide them for you.
https://linustechtips.com/topic/199313-gtx-780-power/
That CPU is like a Toyota while that GPU is like a Jaguar. The toyo just can't keep up and if the jag needs to wait for the toyo you can't use all the power the jag has.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/199313-gtx-780-power/#findComment-2701670
upgrade to fx 6300 atleast like tomorrow.or now. 780 with a bulldozer...hard to digest
well one thing to do is upgrade your cpu to a fx 8000 one and a mobo with a 990fx, you are gonna get a bottleneck running a gtx 780 with a fx 4100.
well if he changes the mobo too he might aswell go intel
https://linustechtips.com/topic/199313-gtx-780-power/#findComment-2701701
"Rawr XD"
https://linustechtips.com/topic/199313-gtx-780-power/#findComment-2701746
