I was given a budget of $900 as my graduation present for a new computer.
This is my first build and I have learned a lot with it.
The specs are;
Gigabyte Z77-UD3H
Intel i5 3570k
Corsair H60
MSI Power Addition GTX 660 Ti
Corsair Vengeance Blue 8GB (2x4GB)
WD Blue 1TB HHD
Antec Three Hundred Two case
I went over budget so the PSU is just a 50W rocketfish brand from Best Buy. This is the first thing I am going to upgrade when I can.
Future planed upgrades:
Plextor M5 Pro SSD
Corsair TX650M
GTX 660 Ti SLI
I will be using this computer for gaming, Autodesk Inventor (3D CAD), 3D CAD rendering, Photoshop, and some 3D animation.
I chose the GTX 660 Ti with the intention of going to SLI in the future
Here is the case, its not a bad case. I chose it over other budget cases because of the USB 3.0 and the hard drive bays are facing outward.
And here is a couple of pictures of the inside
The cables on the PSU where very short so I could not run them through the back of the case sadly
https://linustechtips.com/topic/19882-my-first-build/
Looks great! However, you could try and do some cable management to not only increase the looks of your build, but also the performance.
Good specs, might want to tidy up those cables. Otherwise, great job!
The cables from the PSU where too short to do much of any cable management. And since I plan on upgrading the PSU soon I didn't bother much.
Thanks for the feedback.
https://linustechtips.com/topic/19882-my-first-build/#findComment-235405
Sure, and that makes sense. It shouldnt hinder your airflow that much, and if your upgrading soon, theres really no point to spending a lot of time on it.
https://linustechtips.com/topic/19882-my-first-build/#findComment-235422
Nice! Gotta get a better psu! :P
MSI R9 290 Gaming | MSI Z77 MPower Big Bang | XFX Pro 750W Black Edition | i7-3770k @ 4.5GHz | Corsair H100i | GSkill Ripjaw 2x8Gb | NZXT Phantom 410 Gunmetal | OCZ 128 Gb Vertex 4 | Samsung 250Gb 840 EVO | 1&2 Tb Seagate Barracuda | Logitech G510 | Logitech G700 | Logitech G35 | 3 x LG E2442V
-it24-
https://linustechtips.com/topic/19882-my-first-build/#findComment-244035
I might put the H80 or what ever that liquid cooler is in push pull, might** drop your temps down 5-10 degrees centigrade
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/19882-my-first-build/#findComment-244193
