I need help building my first gaming PC! I have used PCPartPicker to build 3 different computers within my budget. However, I'm unsure as to which one I should build. Could you guys possibly tell me which one is the best one for my use of purpose, please. Or, if you can build a better machine in the same price range, I would love you forever.
Budget: Up to £600
Aim: Web browsing, using MS Office, playing games such as Far Cry 3, Titanfall, Metro Last Light, GTA, Batman Arkham games, Minecraft, Roblox, DCUO, Assassins Creed, APB Reloaded, Runescape, etc. I would like to play these games in the highest settings possible at high, playable FPS. So, for example, play them in ultra/high settings with at least 50 FPS.
Monitors: I will only use one monitor for the time being. Also, if someone could suggest a monitor that won't make a hole in my wallet, that would be awesome, as I have purposely left one out of my build. The reason being is because there are a lot of monitors on Amazon which are around the same price range, and all with good reviews; making it hard to pick one.
Peripherals: I have a mouse, keyboard and headphones. I will upgrade my keyboard and headphones to a gaming headset and keyboard in the future when I have more money to spend on them. In the meantime, if anyone could recommend any good ones, or build a PC from scratch with them included within the £600 price range, that would be amazing!
Why am I upgrading/building: Simple. I currently use a HP Pavilion G6 series laptop for gaming, which is over 4 years old. It only has 4 GB of RAM; a AMD E2-3000M APU with Radeon HD Graphics running at 1.80 GHz processor; and a AMD Radeon HD 6380G graphics card. This literally makes it impossible to play any games on this machine, let alone any actual, good games, such as Batman or BF4.
Preferences: I don't really have any. I know that the builds I have in this post are not the best, obviously. However, with that being said, I will most likely upgrade my CPU and GPU, likewise with RAM near Christmas, when the prices drop. Until then though, I need a good enough gaming machine to play games on. I will also get an SSD in the near future, probably in a month or two. As far as OS goes, I have never used Windows 8, so I can't say much about that. However, I know for certain that I will get Windows 7 unless Windows 8 is better.
My builds:
#1: http://uk.pcpartpicker.com/p/JDRwmG
#2: http://uk.pcpartpicker.com/p/9rFmNG
#3: http://uk.pcpartpicker.com/p/qTLdGX
Like I said above, if anyone can build a better machine in under £600, please feel free to do so for me. This will be my first build, so I am new to this kind of stuff, so I don't really have as much knowledge as most of you here. Hence why I have come here for help. That being said, I just want to thank you guys in advance for helping me out (those of you who do  :P ). Anyways, I'll be back later. PLEASE HELP ME!
https://linustechtips.com/topic/198079-first-gaming-build/
1 or 2, the processors are better bang for your buck with clockspeeds of 3.5GHz, otherwise just personal preference i guess, correct me if i'm wrong, experts.
Build: GPU: MSI GeForce GTX 780 CPU: Intel i5 4690 MoBo: AsRock Fatal1ty H97 Killer RAM: Kingston HyperX Beast 16GB PSU: Seasonic 550W 80+ Gold Case: Corsair Obsidian 500R
https://linustechtips.com/topic/198079-first-gaming-build/#findComment-2685825
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($241.98 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.99 @ Newegg)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard ($144.99 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($84.98 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($55.98 @ OutletPC)
Video Card: Asus Radeon R9 280X 3GB DirectCU II Video Card ($298.47 @ Amazon)
Case: Corsair 450D ATX Mid Tower Case ($99.99 @ Newegg)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply ($67.99 @ Micro Center)
Total: $1011.37
Generated by PCPartPicker 2014-08-15 11:27 EDT-0400
$10 over budget but a great build
https://linustechtips.com/topic/198079-first-gaming-build/#findComment-2685842
there's no reason to go above 8gb in the near future.
if you're planning on ugrading the CPU, gtet this and overclock it until you can get a 4690k
http://uk.pcpartpicker.com/p/YcWJpg
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
https://linustechtips.com/topic/198079-first-gaming-build/#findComment-2685862
Total: $1011.37
note that he's in the UK, so prices are different there.
https://linustechtips.com/topic/198079-first-gaming-build/#findComment-2685869
CPU: AMD FX-6300 3.5GHz 6-Core Processor  (£73.92 @ Amazon UK)
Motherboard: MSI 970A-G46 ATX AM3+ Motherboard  (£53.96 @ Scan.co.uk)
Memory: Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory  (£64.49 @ Amazon UK)
Video Card: XFX Radeon R9 280 3GB Double Dissipation Video Card  (£149.14 @ Scan.co.uk)
Case: Corsair 200R ATX Mid Tower Case  (£40.74 @ Aria PC)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  (£31.03 @ Amazon UK)
Operating System: Microsoft Windows 7 Professional SP1 (OEM) (64-bit)  (£44.99 @ Amazon UK)
Total: £494.21
Generated by PCPartPicker 2014-08-15 18:53 BST+0100
https://linustechtips.com/topic/198079-first-gaming-build/#findComment-2686608
