After leaving my PC on for a few hours, I notice Battlefield 4 is laggy and stuttery. My temps are fine so the only thing I can think of causing this is a memory leak. It has been said that Battlefield 4 has... issues with RAM. Nothing else has a problem running after my PC's been on for a few hours. The problem is that I don't know how to check for a memory leak.
I get 60 frames at 1080p on a dual core APU. Ask me how.
AMD FX 8350 CPU / R9 280X GPU / Asus M5A97 LE R 2.0 motherboard / 8GB Kingston HyperX Blue 1600 RAM / 128G OCZ Vertex 4 SSD / 256G Crucial SSD / 2T WD Black HDD / 1T Seagate Barracude HDD / Antec Earthwatts 650W PSU / Coolermaster HAF 922 Case
https://linustechtips.com/topic/197587-suspect-memory-leak-causing-bf4-stuttering/
Just open a task manager & check memory there. I also had memory leak once in BF3. Suddenly felt terrible stuttering & when I checked task manager, almost all 8gb was in use (I had 8gb in the past). Rebooting helped. Hadn't that issue since that.
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
I don't really want to have to reboot all the time though.
Before playing BF4 ......................................................................................... After playing BF4
Nothing out of the ordinary. Use afterburner to see if it is filling up your VRAM.
Simple Stryker (Now Finished  ;) )
The Terrible HP
What do I look for in Afterburner?
What you are looking at. Play BF4 with afterburner open. If the stuttering happens again check afterburner for the VRAM and RAM usage. It will tell you the Max used.
The Terrible HP
It happened again.
I made the polling 10 seconds in Afterburner because I was in there about 5 minutes
it seems that the latest patch have broken something
user are reporting multi gpu setups not working properly
missing mantle options
if you happen to be using mantle in BF4, disable it and revert back to DX11 just to be sure
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
I don't use Mantle in BF4 because it sucks. I didn't have this problem before I moved the game from my old ssd to my new one but I'm pretty sure that can't be the problem.
when you move the game from the old SSD
was it a copy or a fresh install?
does this happen with other games?
It was a copy and paste but I redownloaded it from Origin and it took about 2 minutes for it to recognize it. I have many other Origin games on there and it's fine. It's the game.
yea the BF4 game with the recent patch is broken
I don't know what you are smoking sir but mantle is quite nice:)
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
it has framerate issues on a 280X.
Interesting... I use it on my HD 7790 with not probs, must not be optimized with the 280x...which wouldn't make sense
it had problems on the 7970 which is why it has problems on the 280x
