 So I'm new to PC building and this may be my first build as I am moving from gaming on a Mac and console (waiting for those special comments). I'm not sure if I should go for a cheaper build or if I should just go straight along with and I am planning to use it with the new Asus ROG Swift 1440p 144hz monitor: http://uk.pcpartpicker.com/p/ZKQGhM
And here's the build for people who cba to use the link:
CPU: Intel Core i7 4790k @ 4.0 base
CPU Cooler: Corsair H100i
Mobo: MSI Z97 Gaming 7
RAM: 2x8GB of Corsair Dominator Platinum 1866mhz
SSD: Samsung 850 Pro 256GB
HDD: Seagate Barracuda 7200RPM 3TB
GPU: Asus Matrix Platinum GeForce GTX 780ti @1.1ish ghz base clock
PSU: Evga Supernova G2 750W 80+ Gold
All inside a nice black and red NZXT H440 with 3 140mm Corsair AF140 Red LED.
BTW I have spent about 6 months refining this list but it still might not be the best so I'd appreciate any feedback, thanks.
EDIT: I have refined the build even more so by incorporating some ideas on this youtube comment I wrote. The part list is here http://uk.pcpartpicker.com/p/Whn88d
Or:
CPU: Intel Core i7 4790k @4.0ghz base
RAM: 2x8GB of Corsair Dominator Platinum @1866mhz
SSD: Samsung 840 EVO 250GB
HDD: WD Black 7200RPM 2TB
GPU: Asus Matrix Platinum Geforce GTX 780 Ti
PSU: EVGA Supernova G@ 750W 80+ Gold
ODD: Samsung SH-224DB/RSBS DVD/CD Writer
All inside a nice black Corsair Graphite 760.
And by the way I put the 750W PSU so I can put in another GTX 780 Ti for SLI and 2TB and 16GB of high speed ram for video editing and such.
https://linustechtips.com/topic/197302-first-build-plan/
The GPU is kind of a waste of money, get some cheaper 780ti, like gigabyte or the DCUII asus one
Computer Specifications:
AMD Ryzen 5 3600  Gigabyte B550M Aorus Elite | ADATA XPG SPECTRIX D50 32 GB 3600 MHz | Asus RTX 3060 KO Edition CoolerMaster Silencio S400 Klevv Cras C700 M.2 SSD 256GB
1TB Crucial MX500 | 1 TB SanDisk SSD Corsair RM650W
Camera Equipment:
Camera Bodies:
Olympus Pen-F Panasonic GH3 (Retired)
Lenses:
Sigma 30mm F1.4 | Sigma 16mm F1.4 | Sigma 19mm F2.8 | Laowa 17mm F1.8 | Olympus 45mm F1.8 | Panasonic 14mm F2.5
https://linustechtips.com/topic/197302-first-build-plan/#findComment-2675809
a little cheaper and will be better with the ROG swift
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (£227.94 @ Aria PC)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  (£81.59 @ Aria PC)
Motherboard: MSI Z97-G55 SLI ATX LGA1150 Motherboard  (£85.16 @ Scan.co.uk)
Memory: Mushkin Blackline 16GB (2 x 8GB) DDR3-1600 Memory  (£110.27 @ Aria PC)
Storage: A-Data Premier Pro SP900 256GB 2.5" Solid State Drive  (£118.79 @ Amazon UK)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card (2-Way CrossFire)  (£318.38 @ PC World Business)
Operating System: Microsoft Windows 8 (OEM) (64-bit)  (£72.77 @ Ebuyer)
Total: £1583.99
Generated by PCPartPicker 2014-08-14 08:00 BST+0100
https://linustechtips.com/topic/197302-first-build-plan/#findComment-2675980
Total: £1583.99
CoolBeans, I'm planning to record and I heard Shadowplay is pretty good so I'm trying to go for a nVidia build. And guys, I've got a budget of around $2000 or about £1600-£1700.
https://linustechtips.com/topic/197302-first-build-plan/#findComment-2676108
well you will be able to fit 2 780s in your budget http://uk.pcpartpicker.com/p/q2Qfxr
https://linustechtips.com/topic/197302-first-build-plan/#findComment-2676114
Hey AmazingHalfAsian,
good choice with the hard drive. The WD Black edition is exactly for gaming and maximum performance. It would be a great fit for your first build. :)
Cheers!
CK_WD
If you think I helped, like!  :P
www.wdc.com
https://linustechtips.com/topic/197302-first-build-plan/#findComment-2676214
