PCPartPicker part list: http://pcpartpicker.com/p/vDMTZL
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($109.98 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.98 @ OutletPC)
Motherboard: Asus M5A97 R2.0 ATX AM3+ Motherboard  ($78.79 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($87.31 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($51.98 @ OutletPC)
Video Card: Asus Radeon R7 260X 2GB DirectCU II Video Card  ($126.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($43.33 @ Amazon)
edit: changed some things
Edited by rhysman2000
  • Intel i5-4690K | MSI Z97 PC MATE ATX | Corsair Vengeance 8GB (2 x 4GB) | MSI Radeon R9 290 4GB TWIN FROZR | Corsair SPEC-01 RED | Intel 520 Series Cherryville 120GB 2.5" Solid State Drive | EVGA 600B 600W | AOC e2050Swd 60Hz 19.5" Monitor | Cooler Master Nepton 140XL
https://linustechtips.com/topic/197134-first-build-does-everything-look-right/
It's going to be used for moderate gaming with no plans to do much overclocking and surfing the web.
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($112.09 @ NCIX US)
Motherboard: Gigabyte GA-B85M-D3H Micro ATX LGA1150 Motherboard  ($74.23 @ OutletPC)
Honestly I wouldn't get an i3. It's not worth the money that Intel is charging for them. Get an FX-6300. Also get an EVGA 500B for power supply. Otherwise it looks good.
"Rawr XD"
You can't oc an i3. Stock cooler is more than enough. Put te extra money toward an r9 270.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
Motherboard: MSI 970A-G46 ATX AM3+ Motherboard  ($78.98 @ OutletPC)
Memory: Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory  ($79.99 @ Amazon)
Video Card: Asus Radeon R9 280 3GB DirectCU II Video Card  ($198.50 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($37.99 @ Mwave)
Monitor: LG 22M35D 60Hz 22.0" Monitor  ($105.56 @ NCIX US)
Total: $732.97
Generated by PCPartPicker 2014-08-13 19:19 EDT-0400
i would pentium k as you will be able to upgrade to something like a 4690k in the future without needing a mobo.
also say get cheaper ram and try and get a 270 or 265
or what cool beans suggested
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
I'd recommend this.
The pentium is plenty for gaming, as shown in Linus's comparison video from a few weeks ago. Also, if you don't mind buying used, then you'd be able to get a 280x in your system, while spending less than what you had listed in your build. You can use that extra money to get an SSD or upgrade somewhere else.
Hope I helped.
//ccap
I'd recommend this.
Hope I helped.
Are you sure that the Pentium won't bottleneck the 280X?
May I refer you to 4:40 in the video.
As long as you overclock it to its maximum potential then you have the same performance or close to a 4790k. (EDIT: After re-reading, it's not actually as simple as I made it seem. The 4790k is a much better CPU, a lot better at that, but you could get away with a pentium G3258 in your case.)
//ccap
Nice thought and that is indeed what the video says. But the gpu used for the benchmarks was not mentioned and it is quite possible that it was maxing out and therefore not fully utilizing the cpu.
