Hey guys! So I have this friend who gave me a Pentium 4 in my fucking school! I wasn't really sure how to take it safely home, so I just wrapped it around a cloth and put it in my pocket :wub:. I hope it's good.
Well the problem isn't really that. I just wanna know of the Pentium 4  works on my configurations of CORMAC. (in signature)
Will it work on MSI G31TMP21? Hope it does.
If more info is needed, then please ask so :)
Thanks in advance :)
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
https://linustechtips.com/topic/196794-will-it-work/
lol put a cpu in your pocket :P are all the pins straight in the bottom ?
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669084
lol yes. I've not yet checked it though. I hope it's not bent.
I don't know about the bent thing, but if it was not bent, will it work in my mobo?
COMING SOON
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669098
can you take a pick off it? ill check because it may break your mobo
|| MAELSTROM ||
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669100
You'll have to wait for about half an hour for that. I've kept my canon on fucking charge..
COMING SOON
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669102
dw im patient just tag me or reply when you can :)
|| MAELSTROM ||
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669106
Cool :)
COMING SOON
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669136
AFAIK, It is this one :)
http://ark.intel.com/products/27455/Intel-Pentium-4-Processor-516-1M-Cache-2_93-GHz-533-MHz-FSB
COMING SOON
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669204
I imagine it would work. That's a 775 board if I recall so pins aren't an issue on CPU.
So you say it'd work?
CPU : http://ark.intel.com/products/27455/Intel-Pentium-4-Processor-516-1M-Cache-2_93-GHz-533-MHz-FSB
MOBO: http://www.msi.com/product/mb/G31TMP21.html#hero-specification
COMING SOON
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669277
CPU isn't on the list but it has Pentium D support so the microcode should be there.
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669357
It better support it. Well, what all changes do I have to do after I put it in the socket? BIOS? Probably some Drivers update. What else?
COMING SOON
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669368
I don't think that CPU is compatible with that motherboard.
Intels supported chipsets for that CPU:
http://ark.intel.com/products/27455/Intel-Pentium-4-Processor-516-1M-Cache-2_93-GHz-533-MHz-FSB#@compatibility
Intels supported CPUs for that chipset:
http://ark.intel.com/products/31913/Intel-82G31-Graphics-and-Memory-Controller#@compatibility
Edit: A little more info on the topic. The LGA 775 socket had several variations, which were not cross-compatible in any way. The CPU support of a specific motherboard could be identified by the CPUs that worked with that chipset, and vice-versa. I wouldn't risk putting a CPU that isn't compatible into the socket as I believe some of the sockets were even wired diferently.
"PSU brands are meaningless, look up the OEM."
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669380
should be pretty much plug'n'play.
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669389
@FizzyFantom says it ain't gonna work :(
COMING SOON
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669434
Can't hurt to find out.
It has netburst microcode on the board (presler) so it could work.
What's the specific model of current CPU? odds are the terrible netburst ipc + long pipeline won't make this much of an upgrade
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669438
Depends how much you value the board and CPU. Unless you can find someone else who can tell you what happens when this processor is put in this mootherboard (or at least one with the same chipset) then you don't know what's going to happen. It's most likely just going to fail to post or spit out some error, but it could damage the CPU or the mtoherboard in some way. It's up to you, but I wouln't do that with hardware I actually value.
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669460
Well I tried a Prescott (I think it was anyway) in my G31 board and it just wouldn't post. but that board only had support for conroe.
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669472
Alright. It's your call OP.
I will try this tonight. Hope everything goes well :unsure:
COMING SOON
https://linustechtips.com/topic/196794-will-it-work/#findComment-2669864
Please tell us how it goes, for anyone else who may be looking for similar information :)
Aye Aye Captain! :D
COMING SOON
https://linustechtips.com/topic/196794-will-it-work/#findComment-2670055
