Intel cooler replacement
Go to solution Solved by heavygrounds,
Yeah.. Didn't think of that. I'll probably buy the 212 evo. But how silent is it?
I find it to be the best for its price. If you want ultimate silence, replace the fan that comes with the heatsink and you'll be gold.
212 evo is a cheap as its get my 8 bit friend
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/196705-intel-cooler-replacement/#findComment-2668508
If you do not want to spend more than 15$ you're going to end up with a cooler which performs just as bad as the stock Intel one...
INTEL I7 4790K @4.6Ghz |  ASUS Z97-A  |  CORSAIR Vengeance Pro 1866Mhz 16gb | NVIDIA GTX 780 | NZXT H440 White | CORSAIR RM750 | SAMSUNG 840 EVO | WD Caviar Black 1TB | LIQUID COOLED |
https://linustechtips.com/topic/196705-intel-cooler-replacement/#findComment-2668526
I don't care, I just want my pc to be silent.
by performance i mean noise as well... cheap coolers are usually loud, so i would recommend a cheap heatsink and a decent fan if you want silence.
https://linustechtips.com/topic/196705-intel-cooler-replacement/#findComment-2668534
https://linustechtips.com/topic/196705-intel-cooler-replacement/#findComment-2668545
