Current RIG:
CPU: AMD FX-6100 (planning to Upgrade to FX 8350)
MOBO: ASUS M5A78L-M LX (planning to Upgrade to MSI 970 Gaming)
RAM: Kingston Hyper-X @ 1600Mhz
HDD: Seagate 1 TB and Sandisk Ultra Plus 128GB SSD
PSU: Aerocool Strike-X 600W 80+ Bronze
Monitor: 24" LG LED @ 1920x1080 (HDMI Cable used)
GPU: Asus GTX 550 Ti
CPU Cooling: Corsair H60 Liquid cooling
Case: NZXT H440
Hi, I'd like to ask the community about a problem I encountered just recently.
I noticed that my CPU Load was fluctuating randomly at IDLE.
Core 0, 3, 5 was Fluctuating from 2-3% to 45-90% Randomly at IDLE
while Cores 1,2,4 was just 2-4% Load at IDLE
and I also Noticed that my Temp at first was 45 deg Celcius at Idle, then I used an Electric Fan to directly Push air into the Case
(note: I removed the side panel)
Then the Temp was at 20-30 deg Celcius.
I also recently Overclocked my CPU from 3.3Ghz to 3.6Ghz, my FSB constant 200Mhz and my Multiplier from 16.5 to 18
But I reverted this back to 3.3Ghz.
I will be Upgrading my Mobo this coming Saturday from the Asus one to the new MSI 970 Gaming.
(note: I chose the 970 Gaming because I will be only doing a Single GPU config + its cheaper than the Gigabyte 990)
Question(s):
 Is there any problem with my CPU? or is it the CPU Cooler thats not functioning properly?
any Feedbacks is greatly appreciated. Thank you in advance!
https://linustechtips.com/topic/196644-cpu-load-fluctuations/
About CPU load things. While on idle CPU goes from 2% to 10% normally because of windows/OS. The fact that you are getting bigger usage means that you have some background process doing stuff.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/196644-cpu-load-fluctuations/#findComment-2668848
What program would you guys suggest, for me to check the detailed Services that are running behind my PC.
https://linustechtips.com/topic/196644-cpu-load-fluctuations/#findComment-2669404
Task manager and Google work really good together in this. NZXT CAM is also nice to find programs thats use your resources but I would still use Task manager for it.
https://linustechtips.com/topic/196644-cpu-load-fluctuations/#findComment-2669874
