Hello Everybody,
I just joined the community after following Linus for a couple months and learning quite a lot  :)
Hope you guys can tell me what you think of the system so far and maybe give me some advice. Open for any criticism!
So lets go!
1. Budget & Location
I am a student in Animation and VFX-Design in Germany so while I will post the current conversion from Euros into USD, please be aware that most parts are usually more expensive here. For example a Xeon E5-2620 is 425USD in the US but at least 465USD (converted) in Germany. I would like to stay below 3000 Euro or $3880. However if you say that i will get significant performance increase with $150 more then that is fine too.
2. Aim
I am currently in my first semester, but I know that this is what I want to do for a living. Thus I will be using programs like Maya, 3ds Max, Nuje, After Effects and probably particle programs like Hudini in the near future.
3. Monitors
I currently have 2 Samsung Syncmaster P2370HD monitors, which are by no means the best but they were on sale :D (2 years ago)  I might add another monitor later on, but right now 2 seems enough.
4. Peripherals
I should buy a mouse as my Performance MX isn't very suitable without a middle mouse button -.-
5. Why are you upgrading?
My current system (below) is having trouble with medium amounts of particles and clones in 3D Programs such as Cinema 4D. I'd also rather have a dedicated work system as myine is layed out for gaming.
Current System:
Mainboard: Gigabyte GA-x58-UDR3
CPU:       Intel i7-930 @ 2.80 GHz
GPU:      Gigabyte GTX-670 OC WF3
RAM:      24Gb DDR3-1600 Corsair Vengeance LP
Sound:   Auzentech Xi-Fi Forte 7.1
HDD:      2x WD 500Gb @ 7200rpm
SSD:      1x OCZ Agility 3 120Gb
Case: Coolermaster HAF932
My plans for the WS:
Mainboard:    Asus Z9PE-D8 WS
CPU:              2x Intel Xeaon E5-2620 @ 2.00GHZ (boxed)
GPU:             PNY Quadro K4000
RAM:             32GB DDR3-2133 Corsair Dominator Platinum DIMM Kit (debatable)
HDD:             WD Caviar Black 4TB
SSD:             Samsung SSD 840 500Gb ;)
Case:            Corsair Obsidian 900D (very debatable!!!)
PSU:              No Idea what I need :D
CPU Cooling: ???
Allright so now a little bit about me and my PC experience. In the past I have done some pretty stupid things like buying that Vengeance RAM. Basically I always wanted a sick PC even if I only use like 5%. Thats why you see the 900D in the list. BUT I dont want to waste my money anymore and it feels pretty stupid to spend 350Euro on a Case. I bought all this RAM only to find out that it makes almost no difference in rendering for me right now. As far as the case goes, I would like it to be fairly quiet because I will likely do overnight rendering.
With this system it will be my first real decision that i will dedicate my time to work and not gaming. Thus I do not need any show-off value or unneccessary parts, I want to get the maximum performance for under 3000 Euro
If I left anything out, please let me know!
-vT
5.1GHz 4770k
My Specs
Intel i7-4770K @ 4.7GHz | Corsair H105 w/ SP120 | Asus Gene VI | 32GB Corsair Vengeance LP | 2x GTX 780Ti| Corsair 750D | OCZ Agility 3 | Samsung 840/850 | Sandisk SSD | 3TB WD RED | Seagate Barracuda 2TB | Corsair RM850 | ASUS PB278Q | SyncMaster 2370HD | SyncMaster P2450
https://linustechtips.com/topic/19648-my-first-workstation/
I would get more, cheaper RAM, the platinum is unnecessary, also higher freq won't help you, stick to 1600 mhz
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
https://linustechtips.com/topic/19648-my-first-workstation/#findComment-232280
why wouldn't i benefit from higher frequencies? I crosschecked, the board can do up to 2133MHz.
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/19648-my-first-workstation/#findComment-232452
I know it can do, but application won't render/create faster, there are tests all over the internetz, going from 1600 to 1866 actually drops in performance sometimes.
https://linustechtips.com/topic/19648-my-first-workstation/#findComment-232489
alright, well since i already have 1600MHz (CML32GX3M4A1600C10) Corsair Vengeance LP i guess ui will just use them. If I find out that 32Gb is not enough. do i have to buy the same kit again or can i chose whatever quad-kit i want?
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/19648-my-first-workstation/#findComment-232533
Also, what kind of power supply would you guys recommend?
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/19648-my-first-workstation/#findComment-232900
I would buy the same kit, just to be sure, for a PSU i would recommend building your system on pcpartpicker (link in my sig) and you will see the recommended wattage, buy a Seasonic, Corsair or XFX, which one is more appealing, a bit over the recommended wattage.
https://linustechtips.com/topic/19648-my-first-workstation/#findComment-232964
By my own calculations, using the limits intel and nvidia write, i get to 290W. However that is without the ram. So I figured I can't go wrong with a beQuiet! 550W PSU. Any idea how much wattage the ram would need?
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/19648-my-first-workstation/#findComment-233142
Ram is negligible, but pcpartpicker is calculating with all the parts, but yeah, a BeQuiet 550 is more than enough, just be sure it's 80+ silver/gold.
https://linustechtips.com/topic/19648-my-first-workstation/#findComment-233264
FYI, your site doesn't have most of my components :)
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/19648-my-first-workstation/#findComment-237943
  • 3 weeks later...
the only thing that benefits from faster ram is APUs
Case: Cubitek MiniCube CPU: i5-3570k @ 4.7GHz GPU: Asus GTX 670 DirectCUII MoBo: Asus P8Z77-i Deluxe/WD RAM: G.Skill Sniper 2133MHz
SSD: Sandisk Extreme 120GB HDD: WD Black 2TB AIO Water Cooler: Antec Kuhler 620 Fans: Corsair SP120 Thermal Paste: MX4
Headphones: Grado SR-80i Keyboard: Corsair K65 Mouse: Mionix Naos 8200 Monitor: Asus MX279H Phone: HTC One Tablet: Nexus 7 (2013)
https://linustechtips.com/topic/19648-my-first-workstation/#findComment-338192
Could a Mod please close this topic? thx!
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/19648-my-first-workstation/#findComment-338214
