GPU Fan Problem
By
Zepso
in Troubleshooting
in Troubleshooting
Solved by LotMonkey,
It is just like changing a CPU heat sink, just make sure if you remove it to clean the contact surfaces with a little but of nail polish remover to get rid of the old compound and then you can either use the stuff applied to the new cooler or just put a blob of HS paste on each contact point then just screw it back on!
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
play_circle_filled
Latest From ShortCircuit:
