Java Version 7 Update 67 Problem Help
Go to solution Solved by Guest,
Instead of downloading the small setup that will download everything, look for the full/offline setup to download. Here they are : https://www.java.com/en/download/manual.jsp
you're not using a proxy are you?
It looks like it can't make the connection to the download server.
Could be a firewall either windows or in your antivirus.
Try disabling your firewall then give it another shot.
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
