fan problems.
was just wondering before i make a purchase if 3 pin fan male connector will work with a 4 pin female connector?
Yes im pretty sure they work both ways
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
Yes, it will work but there will be no PWM (the fan will spin at the fixed amount of RPM, depending on voltage)
Any unknown button should be pressed even number of times.
