Need help find card
Go to solution Solved by connorpiper,
If you do decide the GTX 760, get the EVGA model.
I am make a pc and I do not now what I should use for the gpu can any one tell me what I should get I have price range of 240$ arond that I what the fastest gpu for the price
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/195455-need-help-find-card/
R9 270x, or GTX 760
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/195455-need-help-find-card/#findComment-2651089
videocardbenchmark.com might help
I like the 760 because I feel it'll be cooler, but it depends on a lot of things
are you likely to use shadowplay and gamestream? if so get the 760
the R9 280 is closer in price to $240, and it's better performing.
Get a good cooler though because it might run hot!
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
https://linustechtips.com/topic/195455-need-help-find-card/#findComment-2651103
Thanks for the fast help
https://linustechtips.com/topic/195455-need-help-find-card/#findComment-2651105
