Hmm, the game that I frequently play is only Dota2 and my system have no problem running it, I want to upgrade my graphic card to run GTA V smoothly on 1920 x 1200 full spec, should I buy a new graphic card or get a GTX660 SLI?
<<< System Summary >>>
  > Mainboard : Gigabyte Z77MX-D3H
  > Chipset : Intel Ivy Bridge
  > Processor : Intel Core i7 3770 @ 3400   MHz  (max : 4017)
  > Physical Memory : 32768  MB  (4 x 8192 DDR3-SDRAM )
  > Video Card : NVIDIA GeForce GTX 660
  > Hard Disk : OCZ-VECTOR150 (240GB)
  > Hard Disk : Western Digital WD10EURX-73FH1Y0 (1000GB)
  > DVD-Rom Drive : ASUS DRW-24B1ST   c
  > Monitor Type : Asus PA248 - 26 inches
  > Network Card : Atheros Communications AR9462 Wireless Network Adapter
  > Network Card : Attansic (Now owned by Atheros) AR8151 PCIe Gigabit Ethernet Controller
  > Operating System : Windows 8.1 Pro Professional 6.02.9200 (64-bit)
  > DirectX : Version 11.00
         Help : Example of usage
https://linustechtips.com/topic/194523-help-with-upgrading/
-snip-
Depends on how much you're looking to spend. If you can spend a lot then get a new graphics card. However if you can't afford a 760 or R9 280, then get another 660
"Rawr XD"
https://linustechtips.com/topic/194523-help-with-upgrading/#findComment-2636980
660 will net you roughly 180-200USD. Is it worth it?
to run GTAv smoothly @ 1920x1200 with your setup @ decent settings, I predict (flame me if I end up being wrong) that you will need a GPU with a lot of memory bandwidth. r9 280, r9 290, gtx 780 etc...
I don't want to sound like an ass (in this case), but two 660's might end up stuttering the **** out of your gameplay.
or, I could be completely wrong and it will work great... although I have my doubts.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/194523-help-with-upgrading/#findComment-2637007
wait this out for another half a year than get a 780, 780 ti or mid level 8xx series
660 sli will be held back by bus bandwith , gpu power, core count etc in gaming and sli won't really open it up as much as you think,
my best friend's running 660ti sli's right now and it was nearly as fast as my single 780... nearly.
Yo soy el hombre murciélago
https://linustechtips.com/topic/194523-help-with-upgrading/#findComment-2637918
