Not if you're doing it via the tool built in by the OEM, You will however lose everything else.
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
If your machine has an OEM copy of Windows installed by the manufacturer it will include a recovery partition, these can be activated in various ways depending on who makes the PC, companies like Toshiba for example allow you to restore to factory defaults and installation by booting the PC up into their recovery tool at the boot select screen. Other brands suggest you make a recovery disk which can be used to activate the partition and restore Windows.
i need to reset my pc to factory settings will i lose my windows ?
Welcome to Linus Tech Tips!
If you restore using recovery partition on an OEM PC = No
If you restore using recovery disk on an OEM PC = No
If you restore using the factory reset built into Windows 8.x = No
If you do a clean install of Windows = No
If you format your hard drive = Yes
"Rawr XD"
