Building a PC and I am going to order a cooler. As of now the CM Seidion 240 is $60 and was wondering if it is worth it to go to a phanteks TC14PE for $65. what difference will I see in performance. Also If you guys have any ideas of good coolers that are like $60 in the eastern U.S. then I am open to suggestions.
Eat Moe Beef
https://linustechtips.com/topic/194026-need-a-cooler/
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/194026-need-a-cooler/#findComment-2630195
Noctua U14S
"Rawr XD"
https://linustechtips.com/topic/194026-need-a-cooler/#findComment-2630239
65$ for a 14PE is a great deal. The Seidon will probably perform a bit better, but has the typical drawbacks of an AIO.
I would go for the Phanteks one.
That purchase wouldn't make much sense.
Error: 410
https://linustechtips.com/topic/194026-need-a-cooler/#findComment-2630255
Yeah, I would go for the Phanteks its the best looking of all the high end CPU coolers IMO.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/194026-need-a-cooler/#findComment-2634604
