gpu upgrade, help :)
By
FatalityDiablo
in Graphics Cards
in Graphics Cards
Solved by Sauron,
I would wait, not because I expect anything gamechanging to come out but because I firmly believe you should keep a gpu for at least 3 years unless your needs change drastically (e.g. you want a 4k display). That said, if you really think your card won't cut it for another year, the 280x is a very good choice.
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning1 -
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
