Hello, for a while I have been planning on building my first system (that of which I'm still waiting on the case only) in the Carbide Air 240. However circumstances have sprung up, which I'll spare you the details of, in which I could swap my original MATX motherboard for a mini ITX one. This opens up the option of my favorite ITX case the windowed blue prodigy.
The PC may go on occasional LAN parties but not often, however I will need to carry it up and down the stairs of my house with ease. I don't plan on having Sli or crossfire in my rig, or passing 8gb of ram so expansion isn't an issue. However I would like to eventually by equipment for water cooling my CPU.
I know this is a harder question to answer as one case isn't even out yet, but I'm an impatient person :D.
Which do you think would be best?
Links:
Prodigy:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811345027&cm_re=Prodigy_blue-_-11-345-027-_-Product
Air 240:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139044&cm_re=Carbide_air_240-_-11-139-044-_-Product
"We hold these truths to be self evident, that all men are created equal, that they are endowed by their creator with certain unalienable rights"
https://linustechtips.com/topic/193689-air-240-or-prodigy/
There is the prodigy M, which is an mATX version of the prodigy, so there is that. But the air 240 is a decently designed case, better laid out than the prodigy/prodigy M IMO as you can fit larger PSUs and it's dust filtered, which the prodigy is not.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/193689-air-240-or-prodigy/#findComment-2625280
Yeah I thought about the prodigy M for a long time before I decided against it due to its internal layout and the fact that it only came in white or black, so I decided on the Air 240. For some reason the prodigy doesn't look appealing to me in the basic black or white even though most cases do. :P
Also I have a corsair cx 600 which should fit in both cases =)
https://linustechtips.com/topic/193689-air-240-or-prodigy/#findComment-2625398
White with a mesh grille looks quite good, almost like the old Mac Pro. I was close to doing a mATX build in the prodigy m, but I decided it was a foolish move based on its limitations, so I've gone for an ATX system and case instead.
PCs
https://linustechtips.com/topic/193689-air-240-or-prodigy/#findComment-2625422
The ITX seems to have a better internal layout and more options in my opinion. However I really like the look of the handles, and the fact that it will elevate it off a surface enough to be useful, as well as an easy way to carry it. But the 240 looks like cable management will be a breeze and look nice, especially being able to flip which side the windows on. However waiting another month for it to come out is sounding harder and harder daily.
https://linustechtips.com/topic/193689-air-240-or-prodigy/#findComment-2625577
The main issue with the prodigy I find is the psu length area, and the lack of dust filters. For the price of it, the front could at least be filtered.
PCs
https://linustechtips.com/topic/193689-air-240-or-prodigy/#findComment-2625916
I expected a decent amount of people to support the prodigy considering there are a lot of builds with it, however it seems everyone's liking the air 240.
https://linustechtips.com/topic/193689-air-240-or-prodigy/#findComment-2628051
The Prodigy is a proven ITX case, fitting potent builds in an ITX form, but its layout doesn't come anywhere near close compared to the Air 240. But if you need portability, the Prodigy gets my vote. You can't go wrong with either one though.
CoolerMaster Storm Scout 2 Black - Intel Core i5-4570 - CoolerMaster Hyper TX3 Evo - Sapphire Radeon HD7950 - Corsair Vengeance Pro 8GB - ASRock Fatal1ty H87 Performance - Seagate Baracuda 1TB HDD - Sandisk SSD Plus 240GB - Seasonic G-550 - BenQ GW2255 21.5" LED Monitor
2016 MacBook Pro 13" - Google Pixel
https://linustechtips.com/topic/193689-air-240-or-prodigy/#findComment-2631352
