I am looking for a case for a build that I am doing and I would like it to be less than £50. I have already looked at the Zalman Z11 Plus case and I like it but I was wondering if there are any other good looking cases with the particular colour scheme that I want for less money. My build has a blue and black colour scheme so I would appreciate if the case was black and either has blue accents or blue LED fans. I would like for it to have a side panel so I can look at the components inside. I would like the case to be a mid tower.If anyone has any experience with building in a certain case then any advice would be very helpful as this is my first build. Thanks for all help in advance.
https://linustechtips.com/topic/193228-case-for-%C2%A350/
If you can find it, the corsair 300R, or the 230T silver with blue LED fans to suit your build, otherwise, the Z11 plus is a decent choice for that price point.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/193228-case-for-%C2%A350/#findComment-2619446
personally i recommend Zalman Z11plus, its really nice case for the price, you can easily add some nzxt leds around the side panel window, many fan mounting points, overall very nice case for the price. :)
GPU: XFX R9 290 Case: NZXT H440 (green) CPU: AMD Phenom II x6 1100t CPU Cooling: Corsair H100i RAM: GSkill Sniper 8Gb 1600 MoBo: Asus M5A97pro Sound: Creative Sound Blaster X-fi Fatal1ty Pro gamers edition PSU: Xigmatek Tauro 700w Headphones: Creative Sound Blaster 3D Tactic Rage Keyboard: Razer Deathstalker Mouse: Razer Ouroboros Speakers: Logitech Z5500 Monitor: Asus VG278HE 27" 144hz
https://linustechtips.com/topic/193228-case-for-%C2%A350/#findComment-2619596
