Hello,
The past few months I have been attempting to troubleshoot a problem with my new computer.
Problems:
Wont Output to a Screen
Error Code 55 (No Memory Installed)
What I Have Done:
Bought New RAM
Replaced the Motherboard
Tried Multiple Cables to Connect to my Monitor
Tried Different RAM Lanes
Cleared CMOS Multiple Times
System Specs:
Intel i7 4770k CPU w/Corsair H105
AsRock Z97 Extreme6 Motherboard
Corsair Vengeance Pro 2x4GB 1600MHz RAM
Sapphire Vapor-X 290X GPU
Kingston HyperX 3k 240GB SSD
2TB Samsung HDD
Corsair RM650 PSU
What can I do to fix this?
post-81443-0-91679500-1407330564_thumb.j
https://linustechtips.com/topic/192970-need-desperate-help/
Try your CPU in a different computer, or try a different CPU in yours.
After what you've tried already, I would say this is your most likely culprit.
Process of elimination my friend.
unfortunately this can be a costly exercise.
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/192970-need-desperate-help/#findComment-2615608
Oh thats very sad... Such an amazing looking build, though not working.. Good luck man, this sucks! I hope you find the problem soon.
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
https://linustechtips.com/topic/192970-need-desperate-help/#findComment-2615736
I never had this issue personally but a friend of mine had the same issue. Changed as well the board and the damn thing didn't want to post on the screen.
He was going through a couple of days trial and error but he was so desperate finally that he removed the battery from the board and waited a minute. After this he started the pc and it looked like it didn't help but then the PC booted up and the issue was gone for good.
I don't know if that helps you at all, but at least it could be worth a try.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/192970-need-desperate-help/#findComment-2616391
I have done this already, but thank you for your response.
https://linustechtips.com/topic/192970-need-desperate-help/#findComment-2616992
Hello,
Problems:
What I Have Done:
Bought New RAM
System Specs:
2TB Samsung HDD
Corsair RM650 PSU
I had an issue similar to this recently and what it turned out to be was the graphics card wasn't seated in the PCI-e slot. I had to push it in the slot quite hard to get it to seat. It's worth a try.
https://linustechtips.com/topic/192970-need-desperate-help/#findComment-2617527
I removed the graphics card and plugged the hdmi/dvi into the onboard and still no luck with the same error.
Is the CPU the most probable cause?
Any and all theories will be welcome
My theory is that the memory controller is on the cpu with newer intel chips. So if you've changed the motherboard and the memory the only point loft in the memory circuit is the cpu.
https://linustechtips.com/topic/192970-need-desperate-help/#findComment-2623109
the controller is indeed on the cpu itself, RMA it if possible.
I5 4670k (Noctua NH U12S), Asus Maximus VI Hero, Nvidia GTX 560 ti Asus DCU II, 8GB Corsair Vengeance Pro, Kingston SSDNow v300 120 gb SSD 1TB Seagate Baracuda, Corsair Carbide 300R
I like pie
https://linustechtips.com/topic/192970-need-desperate-help/#findComment-2623452
