I have a HTC evo lte with non removable battery. I was using it as usual pressed power button to screen off. Okay. 5 minutes later I tried to screen on nothing. I didn't think of it so i pressed and held it thinking it was off. Nothing. I plugged it in to my PC and I get the plugged in plugged out sound repetitively. I am using Cyanogen mod 11 with s-off, and i am fairly advanced with android. Can I get any help. Please
Fedex Ground must be on Horse back, It took 7 days to go 200 miles
https://linustechtips.com/topic/192532-big-problem-htc-phone-help/
Have you tried to hold down the power off and volume up button for 10 seconds to force a restart?
Something like you describe used to happen on my Xperia Z, never caused anything too serious.
Your device seems to have just frozen in a state where the low level stuff such as identifying itself as a USB device to your computer works, whilst higher level stuff in your firmware does not.
Anyway, after you have tried to do the forced restart as I said, if it doesn't help, try to plug your phone in to the wall charger, see if it reacts within 15-20minutes with the charging boot screen etc.
Its Brick man...u should flash the phone older firmware which is offcial...
Cant flash anything nothing is working when i plug it in it doesnt show up
Ive held it like 20 times, and when i plug it in the charge LED does not turn on and I have a wall adapter that tells me if its charging and it shows that it isn't. Ill try leaving it plugged in
I'd recommend you don't leave it on charge if it doesn't appear to be charging.
But it really might be your battery dead unfortunately, which variant of HTC Evo do you have?
HTC evo 4G lte, The latest one. inremovable battery :( I guess i could open it up
Have you tried XDA see if they have methods of recovery?
System Specs
CPU: FX-6350 (O.C. 4.6GHz Stable / 4.8GHz Unstable-incomplete)Cooler: Hyper Evo 212Mobo: 990fxa-ud3 Rev.3RAM: G.Skill 1866 2x4GBGPU: MSI R7870-2GD5T/OC x2 (O.C. 1120/1320-Summer 1160/1350-Winter)NIC: PCE-N15PSU: Seasonic X-650 Gold+Case: CM Storm ScoutStorage: 120 Samsung 840 SSD 2x1TB HDDBattery Backup-APC 650Mouse: G600Keyboard: G510Gamepad: PS3 Dualshock 3 VIA BluetoothMonitor: ViewSonic VX2253 (cheap from craigslist, owned this before build)
