Hello. Does anyone know how to assign an application to a specific sound device and override the Windows default?
I want iTunes to play through my speakers while everything else plays through whichever device is set to Windows default device, whether that be my headphones or my speakers.
I have found something called "IndieVolume" which allows me to do this but I want to avoid paying for it if possible, especially because I don't need 90% of the features it offers.
Maybe you guys can help? I don't want to use anything else to play my music and I might want to do the same thing with another application anyways.
Chris
You guys are crazy. You know you guys are self-destructive. There's a funny farm somewhere and it's got your names written all over it. But I'm gettin' outta here.
https://linustechtips.com/topic/192401-audio-utility/
Easiest way would be to set iTunes output device to whatever you want it to be. I don't know if thats possible because Apple doesn't need such features.
You can do it in OS X, but not in Windows :(
I guess I'll just keep reinstalling the IndieVolume trial.
https://linustechtips.com/topic/192401-audio-utility/#findComment-2614855
