650 ti? Help!
Go to solution Solved by Neutronicsoup,
personally I'd go for the second option unless you have a large amount of applications that you wish to launch at lightning speed. or you could go for a smaller SSD and use it as a cache and spend money on a hdd for storage.
So it is time to upgrade and I have a decisions to make. I am running a 8350 oc to 4.8ghz, Radeon 6450, 8gb ram, and a 5400 rpm 500gb hdd. I a looking to get the Gigabyte GeForce 650 oc and the smasung 840 250gb for a total of about $300 USD. The other option is get the GTX 660 with a 120gb  samsung 840 ssd. Please help me to decide or maybe suggest alternatives. I would like to stay with Nvidia because i would need cuda.
AMD FX-8350 OC to 4.5ghz      Evga gtx 660       SilverStone FT03      Samsung 840 128gb
https://linustechtips.com/topic/19206-650-ti-help/
By the way, go easy Grammar Nazis I'm dyslexic;'#';[p#'; (I'm pretty sure a full stop should go there somewhere :D)
My Deviant Art: http://neutronicsoup.deviantart.com/
Linus quote of the day "Slick you're fired"
https://linustechtips.com/topic/19206-650-ti-help/#findComment-226092
