I'm looking for recommendatinos for a small form factor mATX case, preferably one that supports a Corsair h105.  It would also be nice if it had 5 expansion slots for room between GPU's.  Right now i'm looking at the Lian Li PC-V359 but I was wondering if there are others to look at.
https://linustechtips.com/topic/191957-best-sff-matx-case/
Bear in mind that a Cube case is very wide, so really won't look small in any sense. Unfortunately there's a real gap in Lian Li's range as far as µATX is concerned.
There's always the Prodigy M / Phenom M, which must be mentioned in every case thread.
https://linustechtips.com/topic/191957-best-sff-matx-case/#findComment-2600242
